Well I got my iPod Nano today after recommendations on here. I'm really impressed with it but for one thing, the maximum volume. I have heard that the volume has been set to meet EU regulations but it's too quiet when listening to some tracks. Is there some way to increase the volume?
Are you sure about that? Version 1.4 is the latest, and that has been around for ages. I'd be surprised if it works on the new Nano - the site doesn't mention that it does.
GoPod doesn't work on any of the latest iPod models.
And adjusting the volume in iTunes won't overcome the volume cap either, all you do is make it so that the maximum volume on the iPod is reached before the volume bar is at full.
For example, if you increase a track's volume in iTunes by +100% then when it's on the iPod you will find that that track hits it's maximum volume level at about half volume, and turning the iPod up to full volume will not increase the volume any higher after this point. A track which has not had it's volume altered in iTunes will reach exactly the same sound level, although of course you will need to turn the volume level of the iPod to full in this instance.
At present, there is no way to overcome the EU cap.
