How to improve TV sound?
Discussion in 'Televisions' started by angra, Jan 16, 2005.
  1. angra
    angra
    Dec 23, 2004
    7
    I recently bought a Sony KV-28CL10, and I'm pleased with it's picture, it's very good.
    Unfortunately, I can't say the same about the sound, wich is really poor, too much "canned", whatever the settings I use.
    So, I'd like to know your suggestions in order to improve the sound.
    This TV has 2 SCART's, wich are for the DVD player, and to an digital-TV box. There are no RCA entries, so I'm using the box entries to connect it to my hi-fi, using an RCA cable, but that's not good enough for me, because the hi-fi isn't too strong either...
    I thought of a home-cinema system, but that would only solve the DVD sound problem, not the TV shows, right?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You can use your RCA cable to connect your digital box to a cinema amp. Sounds like you need a trip over to your local Richer Sounds. They do some pretty good budget cinema amps and speakers :)
  3. angra
    angra
    Dec 23, 2004
    7
    Do they sell abroad? (I don't live in the UK)
    What cinema amp do you recommend?
  4. Astaroth
    Astaroth
    Jun 22, 2004
    2,256
    48
    London
    +97
    angra - you may be better off posting that question in the amp forum rather than TV - What people recommend will very much depend on your budget and if you want a small discrete solution or would prefer larger speakers
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Yamaha do a good range of cinema amps.
    Hint : If you put your location in "Your Forum Settings", people will see that you are not in the UK, and may change their advice based on that :)
