How to identify RGB Scart Cable
Discussion in 'Cables & Switches' started by finst3r, Sep 19, 2007.
  1. finst3r
    finst3r
    Sep 19, 2007
    38
    Hi all,
    Apologies if this has been posted before but I couldn't find anything when searching.
    I've got a few scart cables, and I want to know how I can identify which one(s) are RGB. I know I bought one a couple of years back but its got mixed up with a load of others.
    Is there a simple way I can check with my multimeter?
    Thanks.
  2. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,300
    Check and see if pin 7 is connected through - that's the blue wire which is incredibly unlikely to be connected in anything other than an RGB capable SCART.
    Or are you trying to identify one which is RGB only (no audio) - in which case, you need to check and see that pin 3 is not connected.
    Steve
  3. finst3r
    finst3r
    Sep 19, 2007
    38
    Cheers Steve,
    Yes, I'm looking for one containing RGB and audio so I'll check pin 7 for continuity.
    Thanks again.
