How to i record buitl-in freeview with my DVDR
Will4long
I have a Lite-On DVD recorder (model: LVW-5006) connected via scart to my Toshiba 32WLT66 and was wondering how do i record from the TV`s built in freeveiw channels.
I have the my aeria co-ax going into my DVD Recorder then out to the TV and the DVD Recorder has tuned into BBC1,2 ITV & C4 but no freeview channels.
Any ideas as to what i`m doing wrong or how to set-up correctly.
Thanks in advance.
JayCee
Thanks in advance.
You need a scart lead from the TVs AV2 ouput to the DVDRs AV2 input...to record the Freeview signals select this AV2 as the input on the Lite-On using its remote control.
Be aware you cannot record one Freeview channel and watch a different one.
knotpc
Or, if you connect the Scart from the recorder on it's AV1 tv socket to your Av1 socket on your TV.
If you then record AV1 on your recorder you will record whatever you are watching on the TV be it Analogue or Freeview.
Of cause if you turn the TV off you will record Blank.
Note : The TV Coax cable only carries coded Freeview signals, not decoded ones. Hence the Scart connection.
Regards
knotpc
