***, how to get Xbox live working again?
Discussion in 'Xbox Forums' started by Bonesy, Aug 13, 2004.
  1. Bonesy
    Bonesy
    Feb 22, 2002
    1,161
    Wiltshire
    +29
    okay, lightening blew my adsl modem chip up.
    so, after spending a lot, I know have another modem/router, the linksys wag54G.
    can't get it to talk to the xbox though.
    neither automatic, or manual, connection gets them talking together.
    have a wired laptop and a wireless laptop talking to the wag through dhcp.
    so why won't the xbox?
    the xbox error message is check cables.
    tried both automatic and configured IP addresses, nothing.
    noticed the enet port on the xbox seems to have the LEDs built-in. but nothing flashes.
    Has the lightening strike blown my xbox enet ? going though the adsl modem and out? surely not?
    why else would it not connect? what else can I try,
    yours, desperately (and annoyed)...
    Bonesy. :lease:
  2. Bonesy
    Bonesy
    Feb 22, 2002
    1,161
    Wiltshire
    +29
    can anyone tell whether there are lights on the xbox enet port that flash on firing up? before I take my modem back to pcworld :(
    cheers.
  3. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Have you tried cloaning the mac address on the Xbox ? Are you using the linksys wireless bridge or the gaming adapter ?
    If you are using the linksys wireless bridge you need to manually set the mac address on the bridge to that of your xbox, I found that if you dont do this it wont work, it cant route the connection correctly. This is not the case for the gaming adapter apparently (from what I can tell from other posts) I can tell you from experience that the wireless bridge is quite difficult to setup with xbox live, I know, Its what I use.
    Unfortunately, if your modem was killed by a power surge its likely that the ethernet port on your xbox has been damaged if it was connected to the modem at the time of the incident. Ethernet ports are actually pretty fragile, it dosnt take much to kill them. I am on my third network card on one of my PCs, its only a year or so old !
    I have heard of incidents where every electrical item connected up to power in a house effected by a power surge / lightning strike were damaged to one extent or another. You really need to take your xbox out of the equation whilst trying to setup your wireless network. Have you a mate with an xbox you can try configuring it with ?
  4. Bonesy
    Bonesy
    Feb 22, 2002
    1,161
    Wiltshire
    +29
    CHeers Harris.
    Actually, I am not using the wireless to connect the xbox. It is just a normal, straight through ethernet cable, that worked previously, and I have also tried a second straight through cable just in case.
    so xbox is directly wired to linksys adsl modem/router/hub/wireless AP.
    I have tried a laptop connected to the ports on the modem, and it picks up a dhcp IP address fine, using the same ethernet cable.
    does appear that I've fried my ethernet port, doesn't it. bugger.
  5. Bonesy
    Bonesy
    Feb 22, 2002
    1,161
    Wiltshire
    +29
    thankfully, have a mate coming down today, who is willing to bring his UK xbox. so will soon know.
  6. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    I am afraid it does. Unlucky.....Well there is always ebay :)
  7. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Bonesy
    When i got hit by lightning my ethernet port on my xbox was also burnt out - i called up MS and got it repaired as it was still under warrenty - 4 days it took to get fixed and back to me - Of course i never mentioned anything to MS about the lightning strike just told them my ethernet port stopped working :devil:
  8. Pooon
    Pooon
    Dec 26, 2002
    7,453
    Canterbury, Kent
    +1,076
    Yes the lights on the back of you xbox should be on when trying to connect to live, one is green and one is yellow.
  9. Bonesy
    Bonesy
    Feb 22, 2002
    1,161
    Wiltshire
    +29
    bugger.
    just plugged in my mates, and his worked a treat first time.
    so me enet port has bought it.
    only problem is, MS uk ain't going to accept my us xbox for fixing, I bet. smashing.
    oh well.
    cheers for the hel every one.
    one last thing, anyone got a xbox live trial code? if so, tonight, I can get me mate into trialing and joing on his box.
  10. supersonic87
    supersonic87
    Dec 31, 2003
    290
    Swansea, Wales
    well you never know, microsoft (imo)have the best customer service i have dealt with (and there are people with modded us xboxs who have had them repaired by ms uk), just don't say its a us model, but stick a note in the package that says it needs a transformer.)
    Rich
  11. supersonic87
    supersonic87
    Dec 31, 2003
    290
    Swansea, Wales
    you can use account recovery to put the account on that xbox, and when you get yours back do the same again.
    Rich
    oh, and you should be able to reclaim the modem/router on your home insurance.
