How to get video from a cupboard to a TV?
Discussion in 'Cables & Switches' started by darrenking, Sep 12, 2005.
  1. darrenking
    darrenking
    One to sink your teeth into…
    I have some home cinema kit that I love the sound of but would rather have a minimalist front room without masive units full of VCR, Tapedeck (could probably get rid of that),DVD, CD/SACD, Sky, Xbox and Amp. I have also installed a multi room audio system and would like to hide all the kit and head units in a cupboard under the stairs.
    As far as cabling goes the Multi room is easy over CAT 5 and can terminate in the head unit in the cupboard all the 6.1 speaker wire can be run in through the floor/walls or ceiling so no problem there. The remotes can be solved with a Pronto or similar with RF receiver in the cupboard for £200 - £300 but what is the standard way of connecting the video outputs from all the kit to a screen in another room.
    Currently I have a 36” Sony CRT (lovely picture but far to big) and will be replacing this with some flat screen yet to be decided (probably LCD).
    At the moment, the VCR, Sky and Xbox are connected to the TV via the 3 SCARTS the DVD via the Svideo at the front. I am happy with the quality of the pictures as I tend to prefer the sharpness of Svideo over RBG when watching movies.
    My problem/question is when the kit is 10+ meters away from the screen how do I connect it up.
    Is it a job of running 10+ meter SCARTS and svideo leads or is there some clever video switching kit that I have not found yet.
    How is this done in the custom installs that you see in magazines (all though I don’t have that kind of budget, I may get some ideas)?
    I had also thought about a display with separate tuner/drive box, but is there a max length on the connection leads for such displays?
    Any suggestions gratefully received.
    Darren
  2. AMc
    AMc
    Nov 20, 2000
    6,893
    Near Norwich
    +3,490
    You could use an RGB SCART switcher like the B-Tech Quintro+ (£70) to cut down the number of leads to one RGB SCART lead. I've seen 10m SCART leads so you should be OK for that length.
    If you're planning on getting a new TV then component might be a better cable to run with the necessary RGB and S-Video convertors to feed it?
  3. darrenking
    darrenking
    Sorry about my slow response. Have just moved house and the ADSL is still not working :thumbsdow
    Cheers for the help, Looking around Joytech seem to do a good SCART switch so I think i will look at that.
    A second question, I know I can get the RF extender for the Pronto remote, but is there a sister unit for the RF extender that will convert IR signals, I know i will like the Pronto but there is a good chance the wife will want to use the standard sky remote, and i would like the option to use both. That way I stand half a chance of actualy being able to do this lot.
  4. AMc
    AMc
    Nov 20, 2000
    6,893
    Near Norwich
    +3,490
