How to get Sky to other rooms in the house via loftbox.
Discussion in 'Sky Digital TV Forum' started by Burt25, Mar 15, 2006.
  1. Burt25
    Burt25
    Apr 24, 2005
    10
    I wish to set up for Sky in 2 other rooms using magic eyes and distribution box in the loft. My main TV is connected to a triplex ariel socket in the living room. - I have arial sockets in the other rooms cabled back to loft redy for connection.
    Questions are:
    1. Which loft box do I buy (I need a maximum of 4 Tv's)
    2. Do I need power in the loft (The SLX boxes I have seen have power cables??)
    3. Is there any way of telling which cable is which in the loft?
    4. Is there a site of previous post which gives definitive instructions on how to go about this?
    5. Should I just pay someone to do it (Got a quote of £120.00)
    Thanks in advance.
  2. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
    If your sky feed runs straight down to your Sky Box then you don't need a complete loftbox just the distribution amp bit.
    Globals F and T series amps come as 2, 4, 8 and 16 versions. The 2 and 4's do not need power as the Sky box can power them using the 9v from the back of the box.
    Do you have a return cable from the main TV up to the loft area as well?
  3. Burt25
    Burt25
    Apr 24, 2005
    10
    My feed runs direct from the dish to the triplex socket in the living room, I have 2 return cables from the triplex (one for FM feed I assume). Problem is I have 2 triplex sockets in the living room which means I have 5 cable ends coming up to the loft (plus the one connected to the dish) so I could have a problem finding which one I need to connect??
