How to get rid of L -U on Tosh 32
Discussion in 'Blu-ray & DVD Players & Recorders' started by PHOBIC ®, Dec 7, 2004.
  1. PHOBIC ®
    PHOBIC ®
    Oct 19, 2004
    190
    UK
    When powering on, instead of the display going straight to HDD, the display goes straight to L -U. I then cannot select HDD. Nothing happens at all. I can press the DVD button, then back to HDD button, but the display defaults itself back to L-U.
    The manual is a nightmare, and doesnt tell one how to get out of it. All i can make out is that L -U is for Line Dubbing. But i neither want or asked for it, so why its now permanently on the display window is a mystery
  2. SDHoward
    SDHoward
    Nov 1, 2004
    250
    L -U is sort of a channel so its remembering the last channel you were on.
    play with the channel and input select buttons.
  3. Neville Street
    Neville Street
    Jul 11, 2004
    290
    +4
    It is the channel that is selected. Once it is powered up use the channel up button to cycle to a different channel, this should then be the one you see if you switch off and back on. Mine is always on the last channel I used or the last channel it did a timer recording from when I switch it on.
    If you press the "fl. select" button (no I don't know what it means!) it cycles through a range of displays including channel number, bit rate, remaining recording time and the clock (and various combinations of these).
    As far as I know, the L-U will not change whether you have DVD or HDD selected, it relates to the channel it is tuned to (i.e. it is viewing/recording its own output with L-U selected, it is viewing/recording AV2 with that selected, BBC1 with 1 selected, etc.
    Hope this makes sense! NS
  4. PHOBIC ®
    PHOBIC ®
    Oct 19, 2004
    190
    UK
    Thank you guys !
    Changed channel to BBC1 - then powered off - then powered on, IPSO FACTO the display now reads BBC1 !!
    If only the manual was as clear as you guys !!
  5. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    As a matter of interest, you know whether you are on HDD or not by the blue light rather than the display
  6. PHOBIC ®
    PHOBIC ®
    Oct 19, 2004
    190
    UK
    Yeah gotcha ... it was just that the display was reading L-U instead of channel 1 /2/3 etc. never seen it before. And wondered why i couldnt change anything.
  7. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    Your better off having it on AV2 if for example you have a Sky box connected to it.
  8. TVHEAD
    TVHEAD
    Nov 29, 2004
    59
    11
    I keep mine at AV2, this seems to be the most convenient as I don’t have a RF Ariel plugged in and watch cable through the tosh, can anyone tell me the benefits of having the SAT ON selected, besides being able to change channels on the satellite box with the tosh handset, I know it doesn’t effect recording not having it switched on.
