how to get rid of dust blobs?
Discussion in 'Projectors, Screens & Video Processors' started by nadeem1970, Jan 24, 2005.
  1. nadeem1970
    nadeem1970
    I've got Panny A500, last few days ive noticed dust blobs on screen, ive got a can of air , but i dont know how spray the panals, inside........Please can some one help................also i am over 4000 hours on the lamp now..........cheers
  2. LITTLEBRITAIN
    LITTLEBRITAIN
    Nov 28, 2004
    289
    19
    Greater Manchester
    i have the same problem, anyone know?
  3. andrew constant
    andrew constant
    Apr 15, 2002
    209
    london
    +10
    I to have an AE500 and i have noticed a red round blur about 3inches diameter on my screen is this a dust blob ?
  4. nadeem1970
    nadeem1970
    to be honest i dont know, mine is a white blur, tend to notice on dark backgrounds. how many hours have you done?
  5. chic
    chic
    Jul 1, 2001
    5,976
    glasgow
    +871
    see here you should spray the air in where the gold ribbons are, remember keeep the can upright and it should be ok, the best can air i have used is the ones from jessops with the screw on metal tube, it seems the air blast is much stronger and is more effective in removing dust
  6. chic
    chic
    Jul 1, 2001
    5,976
    glasgow
    +871
    might be dust on the red panel, to check if its dust adjust the focus on the pj if its dust the blob will com into focus while the rest of the image will be out of focus
  7. nadeem1970
    nadeem1970
    thanks chic, great link, i will have a go, when the dust problem gets worse, to be honest, when i take things apart, i can never put them back together, so i will have ago when i am feeling brave...............cheers
  8. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Just done my 700 as i got fed up waiting for panasonic to come and pick it up, really simple to do just be carefull, i used a compressor to blow the dust out, i think id left the dust there too long (waiting for panasonic) and it may have burned in to the panel as i can still see a slight marking where the dust was. I would advise u blow it out as soon as possible to avoid permanent damage to the panels.
  9. nadeem1970
    nadeem1970
    where did u get your compresser from and how much did it cost?
  10. Optical1001
    Optical1001
    Jan 30, 2005
    16
    Manchester
    thinking of buying a projector after reading all the problems you guys have been having with dust VB etc etc, i am having doubts now.
  11. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    its one i bought for car spraying and using air tools, a bit overkill for blowing dust out of a projector but miles better than canned air, cost 200 quid from machine mart, u can buy a lot of canned air for that.
  12. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    I seem to have had the worst luck with my pj's over the years but i still say go for it, even with all the problems ive had i could never give up my pj and go back to a conventional tv, well not till they make them "90. Buy one u will never look back.
  13. MikeRJ
    MikeRJ
    Oct 21, 2004
    226
    Plymouth
    Miles better for spraying and inflating tyres, but the air from a compressor will always be dirteier than that from one of the aerosols. Even with a water trap (that isn't fitted to DIY compressors as standard), tiny particles of rust etc. from the air receiver can still get through. I certanly wouldn't use my compressor on a projectors LCD panels.
