How to get Openelec Raspberry Pi to Output 24fps
Superrichie85
Hi I am bit new to XBMC and avforums bare with me :)
I have the latest chipset raspberry pi and I have put openelec's latest Beta on a class 10 30mps SD card when I go to calibrate the refresh rate for each type it only gives me the option to do 50 or 60. When I play a 24fps I get juddering while panning but playing the same film on my dune it doesn't. How do I get the other refresh rates work on the PI?
Any help would be appreciated
next010
In XBMC you should set System->Settings->Video->Playback and enable "adjust display refresh rate to match video". GUI should be set to [email protected]
If you have XBMC 13 then you must change settings level to expert to see such option.
When video plays it should auto jump to [email protected]
If it's not working then try Raspbmc instead, they claim the feature works on theirs.
Superrichie85
That's Brilliant thank you works perfect now :) I am unable to click thank you as a new member but as soon as I can I will come back to thank you
