How to get more from my Harmony Hub?
Discussion in 'Smart Home, Climate Control & Security Forum' started by mrmrh, Nov 3, 2018.
  1. mrmrh
    mrmrh
    Jul 4, 2015
    186
    Dublin, Ireland
    +85
    I have a how many hub to control my LG TV, Nvidia shield TV, Apple TV and Sonos Playbar.
    I seem to be able to control it well through Alexa, very basically through Google Home, and not at all through Siri (unless I setup a HomeBridge server).
    I am able to run the command “Alexa turn off the TV “, however I am wondering if there is an equivalent for Google assistant/home. I don’t have any echoes in that room and loading the Alexa app to run a voice command is very slow, as is manually going to the LG TV remote in the Harmony app.
    Is there something I am missing in Google home to allow me to simply tell the television to turn on?
  2. John
    John
    Dec 13, 2002
    11,570
    +3,217
    I have it set up through alexa using the harmony skill, but never use it because the remote doesnt keep up with the voice command
