how to get into the instalation menu?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by shoestring25, Aug 3, 2004.
  1. shoestring25
    shoestring25
    Feb 2, 2003
    3,997
    essex
    +506
    how do i get into the instalation menu? i need to alter the RF channel on my sky box
  2. johndon
    johndon
    Feb 3, 2002
    1,986
    63
    +122
    If memory serves, it's Services then System Setup then 0 then 1
    HTH
    John
  3. sinbrad
    sinbrad
    If That doesn't work try this...
    services, 4, 0, 1, 0, select
