Hi guys, I'm trying to get my head around the best way to get internet over to my garage?
What would you do...
So above the garage is a self contained 2 bed annex. I would like wifi to be available here. I also want to install 2 IP cctv camera on the outside of the garage.
I tested a powerline adaptor from the house to the garage but that didn't work unfortunately. Can only assume that its because of the consumer units setup?
In the house theres loads of cat6 network points. I had thought of connecting a wifi access point to one of these that is the closest to the garage. (10meters away)
Then fitting a repeater that has two ethernet ports for the cameras in the garage.
What do you think is this a 'normal' way to do this or am I missing something?
Cheers, Devs
Cheers, Devs
