How to get from a standard video out to a co-ax input?
mjkinch
Hi All
I have a wireless camera that links to a box, which has a standard audio and video out socket.
I also have a Labgear Aerial distribution box that has a CCTV input which is a screw in co-ax satellite fitting.
Question is - can I get something to convert the audio/visual output to go into the Aerial distribution box through a co-ax cable?
And also would the quality be OK?
The theory is then the camera feed would be accessible through any TV in the house.
Any help appreciated
MaturityDodger
I don't know if there's any difference on CCTV systems, but usually for video down coaxial you'd want an RF modulator.
Anybody know any different?
un1eash
RF Modulator should do the trick, i was using one with my Sky HD mini box to send sky to the room next door over coaxial cable as the box does have RF outs. It took either a scart or composite input and you select the RF channel to output on. Quality was as good as freeview.
JVC 4K projectors, Denon X3800 & Perlisten speaker reviews, adding a sub to 2-channel + AV/HiFi news
