How to get Freesat in second room
Giddy307
Hi, I have a Humax 1100S in my living room and would like to get it in a second room. The only cables coming in from the satellite dish, come in to the living room. Would a tvlink work or are there any other ways of getting the picture in a second room?
grahamlthompson
In memoriam
Run a flat cat 7 network cable and use a pair of HD baluns
https://www.amazon.co.uk/Extender-N...&keywords=HDMI+extender+with+ir+and+hdmi+loop
https://www.amazon.co.uk/Ethernet-N...d=1552816374&sr=8-3&keywords=flat+cat+7+cable
davedolan
Amazon product
Amazon product
I am having a similar problem, I have ran a cat 6 cable and purchased a HDMI extender (below)
(Amazon product) ,
however still not receiving it at the other tv. getting that red power symbol next to the hdmi icon on my samsung tv, I do not have the HD baluns, why would I need these? I'm not a big techie btw!!
Humax 1100s - hdmi - extender - cat 6 - receiver - hdmi - tv
Appreciate any pointers!
grahamlthompson
In memoriam
(Amazon product) ,
The ones linked to have a hdmi loop out. What are using to provide a HDMI input to the pair you bought at the transmitter end ?
The OP had a Humax Freesat satellite box he wanted to feed a local TV and a second one at another location.
Do you have a similar device like a Freeview-HD or Freesat PVR or other external box that you connect to your main TV. No TV:s have hdmi out so a single TV cannot be used.
davedolan
Thanks for the quick response!
Main tv has co-ax from digital aerial and hdmi input from Humax box (separate dish). Out of curiosity I disconnected the hdmi to the existing tv, and ran it to the extender, expecting that it would run to the kitchen no problem, only about 15m away. This did not work.
Going forward, what would I need to have one humax box serving two tv's, independent of one another (separate channels on at the same time etc)
MJH1962
That's simply not possible. You need two boxes to do that.
davedolan
Noted. Any ideas as to why the hdmi extender did not work? The Humax box is in the living room and I want the tv in the kitchen to receive the Humax output. Hdmi from Humax box to HDMI extender transmitter, over Cat 6, to receiver and back to kitchen TV via HDMI. Am I missing something here??
grahamlthompson
In memoriam
You can use the kit you bought though the option I linked to makes it simpler. because it has a HDMI loop in out sockets.
You need a HDMI spliitter like this one.
Amazon product
A short extra HDMI cable.
Yes you are missing something. The original device I posted a link to would have made it a lot simpler because it has a built in HDMI in HDMI loop out sockets.
You need a HDMI Splitter like this one.
Amazon product
And a short extra HDMI cable. Connect the Humax HDMI out cable to the splitter in. Connect one splitter out to the transmiiter in using the new short cable. Connect the HDMI cable used to the TV remote end to the other splitter out.
Next question do both TV's have the same resolution. say Full-HD 1920 x 1080 then that will be fine. If the remote TV has a lower resolution then the local TV signal will be downgraded. to match the kitchen TV.
Lastly you will need to set the Humax box (You haven't posted the model number) , digital audio out from surround to stereo. If I knew which box I could be more specific..
If it's a second generation Freesat+ PVR . Home - Settings - Picture and sound - Digital Audio out - Change from multi-channel to stereo
davedolan
Amazon product
Amazon product
I don’t have the model to hand but I’m sure I can work it out. Thanks a million
JonMace
much simpler to use an Enigma2 Receiver then you can use android boxes with kodi on additional TVs around the house, with this method you can control the receiver watch and set up recordings etc buy something like the gigablue uhd ue 4k and change your LNB to a unicable and you will have 8 tuners plenty for the whole house
