how to get euro1080
Discussion in 'Televisions' started by sheep, Apr 4, 2005.
  1. sheep
    sheep
    Jan 23, 2005
    296
    +9
    Hi all as some of you may know i am a recent convert to DLP and the Hd possibilities it brings,which leads to to ask how do i go about getting euro1080?,is it worth getting?what equipment will i need please keep it simple i have only just got the basics on Hi-Def etc lol so not to much tech jargon :))
    Sheep
  2. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    To get Euro 1080 (now known as HD1) you need a hi-def receiver, an HD1 smart card inserted into an Irdeto cam and a satellite dish pointing at the old Astra analogue position of 19.2 E. The Quali 1080IR receiver that I have does the business and the image quality is stunning. The programming leaves a bit to be desired. Fine as a demo, but definitely not something that you will want to watch each and every night, unless you want to watch the same programme over and over again!
  3. johnelf
    johnelf
    Nov 10, 2003
    632
    Epsom
    +78
    Please also remember they are converting from MPEG 2 to MPEG 4 this year and all the new channells are being launched in MPEG4 format from June this year.
    The Quali box will not pick up the new format. What i have done is buy a sat pc card (sky star 2) for around £50 and use this with my pc and dish of course. When the new MPEG4 boxes become available, will consider at that time.
    The pc needs to be fast for HD 3.2 or faster, min 1ghz RAM.
    The pc option will also let you watch other channels too inc PROsieben which is also HD at present and unencoded.
    Regards
    John
  4. sheep
    sheep
    Jan 23, 2005
    296
    +9
    so do i need a seperate dish or can i use my sky one?sorry for these newbie questions
    sheep
  5. Dutch
    Dutch
    Dec 5, 2002
    2,582
    3
    North Yorkshire
    +270
    No, you can't use your Sky Digital dish - it's too small and not pointing at the right satellite. As Piers said, you need to have one pointing at 19.2 E, not the Sky Digital position at 28.2 E. Hope this helps.
    Steve
  6. sprattgraham
    sprattgraham
    Dec 10, 2004
    928
    28
    Hertfordshire UK
    +28
    Euro1080 Have Said That HD1 & HD2 Will Start Broadcasting On One Of The Satellites At 28 East From November 2005.
  7. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    It's also highly likely that the HD1/HD2 will also be accessible via SKY+ HD when it launched as a premum standalone channel or bundled in a SKY branded offering.
    If you are interested in SKY's subscription HD service then it may be cheaper to wait (If indeed there is a 2005 launch) and just buy the single STB which will work for both services.
  8. sheep
    sheep
    Jan 23, 2005
    296
    +9
    thanks for all your reply's i think i will take your advice and wait
    sheep
  9. 1080 jawbreaker
    1080 jawbreaker
    Nov 30, 2004
    2,778
    +614
    if they us the DVB-S2 standard instead of the current DVB-S then its still no go for mpeg4. Havent seen any S2 hardware available yet so fingers crossed it wont be S2
  10. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,100
    Manchester
    +712
    DVB-S2 is in its infancy.
    DVB-S2 tuner chips from ST, Connexant, Zarlink and Broadcom are at various stages of development but early engineering samples are only available from 1 or 2 of them.
    There will also be a cost penalty, decreasing over time. Currently I have seen budgetary volume prices (i.e. 1 million or more) of around $12-13 whereas current standard qpsk chips are in the $3-$5 range.
    Moves from DirecTV (USA) mean that it will happen certainly over there and Europe is expected to follow.
    Chris Muriel, Manchester
    (I'll have more info later this month as I will be attending the NAB show, National Association of Broadcasters , in Las Vegas - work-related )
  11. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,080
    +681
    AIUI Sky want to go DVB-S2 with their HD service?
    I wonder if they are going to soft-launch HD they will do so with DVB-S receivers and transmissions - but wait for DVB-S2 before they start delivering to the public?
  12. 2 Point
    2 Point
    Euro 1080 will be one of the 'standard' HD channels that will be launched with the Sky HD later this year.
    You will still have to pay the £10 a month to access the HD content, but this can be added to the most basic package Sky offer.
