How to get best sound?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Sab, Sep 28, 2003.
  1. Sab
    Sab
    Dec 18, 2002
    754
    London
    +26
    I know I have a good stereo hifi system but I am not that satisfied with the sound which is odd. I am using LAT International biwire speaker cable and Van den Hul First Ultimate Interconnects.
    With my Arcam FMJ cd player and amp I usually leave the display off and this does make a difference to the sound. Arcam say in the manual that it sounds better with the display off.
    Does anyone else have their display on in their CD player/amp system? Does it sound better with the display on?
    Do I need better spaekers to get the best out of my Arcam FMJ?
  2. Karma
    Karma
    May 20, 2002
    375
    Birmingham
    +11
    I think you may have answered your own question. If it sounds better to you with the display off, then leave it off. Especially as it is what the manufacturer recommends.
    For what it's worth though, this has been general practice for some time. I have a Meridian CD player with the ability to switch off the display, and Meridian recommend it is switched off for serious music sessions.
    I've found that the player does sound better with it off. But can only tell when conditions are at optimum. ie late at night, when the mains is purer anyway.
    At heavy current usage times (ie early evening) then it is difficult to tell the difference, so I guess the quality of mains has a large influence too.
    Karma
  3. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    I would say the weakest link in your system is the 3802. Speakers should sound great and the FMJ is a winner. 3802 is over-rated IMHO although a good surround amp at the time.
  4. Sab
    Sab
    Dec 18, 2002
    754
    London
    +26
    What would be a good upgrade to my stereo system without spending over a thousand?
    The Denon 3802 will be upgraded when funds allow. Perhaps Pioneer Ax5i? Or would I need a procesor/poweramp combo to get the best out of my speakers e.g. Rotel?
