how to get best picture out of sky+ box to 40inc lcd
Discussion in 'Sky Digital TV Forum' started by angelgrant, Jan 11, 2008.
  1. angelgrant
    angelgrant
    Oct 28, 2007
    113
    +6
    Guy i've connected my sky+ box to my 40 inch lcd but it looks a bit blocky, i've conected my sky+ box to my tv using a scart cable...is there another cable i should be using?
  2. Fatwaz
    Fatwaz
    that is the best way already.one thing you can do is go to services,system set up,picture setings and see that rgb is selected for scart output,this is the best siganl out from a sky+ box you can get though some have said the pal setting works best on their big screen lcd's so have a try of both and pick what looks best for you.
    the trouble is these big lcd's aren't built with SD in mind,they may look sensational in HD but SD really lets them down unless they have a good upscaler inside.
  3. angelgrant
    angelgrant
    Oct 28, 2007
    113
    +6
    cheers for that mate, i'll give that a bang....
