How to get audiophile sound?
jameson_uk
I currently have my HTPC setup with Meedio as the front end using BASS as the music player and ASIO out (via the nForce2 mobo sound) and 192kbps MP3 files. The optical out from mobo is then plugged into my Denon 3803 receiver.
Even though I have a decent set of speakers (KEF Q series), decent cables (QED Silver aniversary bi-wired to fronts) and supposedly a straight unmangled signal from PC to amp, I find the sound a little uninspiring.
I presumed that the weak link here was the fact that I was using lossy mp3 but I have since tried ripping a few (well recorded) albums into FLAC but there was very little in it.
Any ideas on what I can do to improve the sound quality (I know it can be better as with the old DVD player I had some time ago; Pioneer 636; connected via digital coax I got much better sound)
Should I look at file format / player or hardware?
shezzy2k
Get a decent sound card...though it depends how much you want to spend.
You should find info on this forum for the following...
M-Audio 2496, About £60.
RME 9632, About £300.
Lynx TwoB, About £500 (I think)
I have the RME on my system & I'm quite pleased with it.
I hope this helps.
The Dude
For the cheap option, get the MAudio 2496 and use the analogue outputs to feed your amp.
It's actually your 3803 at fault I'd say, it's a not particularly good piece of kit for listening to music.
For starters bypass it's DAC by using the analogue outs on the 2496, then, when you've saved up some money, get yourself a cheap power amp (anything will do) and bypass the 3803 all-together :devil:
Cable Monkey
I presume that you are able to be inspired by music through your amp in other ways? If so what kit are you using and how? (Analogue, digital?). If music via the 3803 has never inspired you then it could be a weak link. If it has then the sound card is a probable cause. I have a 24/96 feeding a stereo amp right now and for the money you are hard pushed to do better.
jameson_uk
I have to admit it is not the best but when I had the DVD player connected digitally it sounded a lot better than the PC so I guess it is probably both the amp and the sound card...
jameson_uk
Surely getting a cheap power amp would defeat the object? I can see that using the PC as a pre-amp would be ok but 5 x100w channels of decent power amp is going to cost a small fortune
jameson_uk
I would be interested in why this would make a difference? If you assume a completely digital route then the ideal route would surely be simply transferring the 1s and 0s from the mp3 files direct to the amp and therefore the actual soundcard should not be doing anything to the signal anyway?
If you are talking analogue then I am presuming that the only reason for a decent sound card would be the DAC but for that money I could buy a top quality DAC anyway. Also using analog out would that not be subject to the windows kmixer and all sorts of resampling before it even reached the soundcard anyway?
The Dude
I thought you wanted Audiophile quality? :devil:
TBH I was only referring to something to use for 2ch use, you'd need a better soundcard than the 2496 for multichannel anyway, the RME would be the best option there, by all accounts...
2ch power amps don't cost too much though, plenty of Rotels crop up in the classifieds here for very reasonable amounts. :)
shezzy2k
I am indeed talking about analogue. I agree that you could probably buy an external DAC, but I assume that the OP is after a one box solution...as I was when I built my HTPC.
eviljohn2
It's not quite that simple as MP3 is an encoded format rather than nice simple PCM.
Although it's stored digitally, it needs extracting and converting before it could be thought of as digital music which you can pass straight to your amp. :)
mark.carline
jameson_uk said:
....and 192kbps MP3 files.....
Thats your problem! - Try reripping CDs in 320kbs format and check out the difference. You'll only gain somthing like 0.01% extra sound quality between 320kbs and losless format (WAV etc) and in my opinion its a waste of time
Find yourself a good reference track and do lots of listerning.
I use the following singles:
INXS - Kick
Dire Straights - Money for Nothing
All of which which has been recorded really well and have good stereo imaging and solid bass.
You might want to consider swapping yout KEFs as I didnt realy rate them. They used to be good (when they where KEF) but now they sold out I dont like the sound of their new speakers. I ended up going for a high end JM Labs speakers (Utopias) but they do make some reasonable cheaper ones.
mjn
Agreed, i'd also feel uninspired by 192kb MP3...ugh....can't think of anything worse, well i can actually, 160kb MP3 :eek:
Re-rip your CD's properly, before spending any money.
jameson_uk
what about FLAC? It is supposedly lossless and takes up about the same space as 320kbps (do you sample at 44.4 or 48 btw?). I tried FLAC and must admit that I did not notice much (if any improvement) will try 320kbps MP3 tonight
Snap. Also use brothers in arms which also has nice dynamics
They are a good 6 years old now (the original Q series) I went for these as at the time they were the best for both home cinema and music (have Q35 fronts, Q95c center and 70s rears) this is now coupled with a BK XLS200 sub
The Dude
did you rip the FLACs from CD? obviously up-converting the mp3's won't get back anything you've lost in the ripping process.
FLAC is your best bet if they're for playing on the PC, no point re-ripping everything into another lossy format, may as well do things properly if you're gonna bother.. :)
jameson_uk
Indeed use Easy CD Extractor and ripped direct to FLAC
jameson_uk
mark.carline said:
I used media player 10 to encode. CDs are encoded at 44 so theres no point going any higher.
I realise CDs are recorded at 44 but I seem to recall reading somewhere that Windows resamples everything to 48 anyway (something about kmixer?) and that is why kernel streaming and ASIO are meant to be better (they supposedly bypass this all)
D
DeeeKaaY
check out exact audio copy, it is free and great. lossless rip to wav file. then use win amp or foobar output to the analogue outputs of a decent card. use xlobby as your interface and bobs your auntie... audiophile htpc. :thumbsup:
avanzato
I use EAC too. I wouldn't say it's easy to set up but I followed one of the guides out there and now have it ripping to .flac, tagging and saving off to my NAS almost automatically. It'll even error check the rips using 'accurate rip' though I seem to have several CD's that aren't in their database yet.
shezzy2k
I don't mean to Hijack the thread so apologies in advance.
What are your opinions on monkey's lossless Vs FLAC form a sound quality perspective?
cwick
Maybe I'm being naive but I'd assume that, both being lossless, they'd sound identical. And if they dont, either one isn't lossless, or someone's talking out of their bottom by describing them as such :D
clockworks
There's not really anything wrong with the 3803 as a preamp, and the on-board DAC isn't that bad - my 3802 sounds pretty good when fed a CD via optical from a Panasonic DVD recorder ( I sold my Linn CDP a while ago, when money was tight).
If you can't hear the difference between 192k mp3 and lossless, there is obviously something wrong, though. I'd put my money on the 3803's power amps being a part of the problem.
I recently renovated my living room, and had to re-install everything. I thought I'd try using my system without the power amps that I normally use for the front 3 channels. It sounded atrocious with stereo music. Plugging the left/right amp back in made a huge difference. Not really noticeable when watching TV, but night and day for music.
Get yourself a secondhand stereo power amp, and use that for the left and right channels. While you're at it, get a another one, and use it to bi-amp the centre channel - that does make a difference for 5.1.
Once you've got some amplification that actually works with real speakers, you can get your front-end sorted, if necessary.
Russell_S
I think you'll find that the audio is still being upsampled to 48khz and so is not bit-perfect. ASIO will bypass the Kmixer but a lot of audio chipsets actually upsample in hardware and cannot be bypassed. This is certainly the case with creative sound cards and I think that is the case with the nForce2. I believe the reason for this is that Microsoft, in their infinate misdom, created the standard that all audio should be upsampled to 48k.
The way to test if you are getting bit-perfect digital audio is to get hold of a DTS encoded 44khz audio file (various test files freely downloadable on the web). If this plays back ok then you do have bit-perfect playback. However, if you just hear mush then it is being upsampled. This is because the upsampling destroys the DTS encoding. Of course, this will only work if your amp has a DTS decoder.
The best audio chipset that I have found that doesn't upsample is the VIA Envy24. Cards that use this chipset are the Chaintech AV-710, Gainward [email protected] and Maudio Revolution 7.1 etc. Get the cheapest one you can find because you are not going to be using the analogue part of the card at all, and because you will not be upsampling, the DAC's won't be used either. So basically, the card will just be passing the digital signal straight through and not processing it in any way.
There is an excellent thread in the HTPCnews forums all about this chipset and ASIO/kernel streaming in general. You can find it here:
http://htpcnews.com/forums/index.php?showtopic=3616
Here is a link to some free DTS encoded audio tracks (use the DTS 44.1khz files NOT the AC3 ones):
http://www.kellyindustries.com/sounds.html
I am using Meedio as my HTPC front end with digital sound running through a Gainward [email protected] sound card with MP3 & Ogg files at 160 or 192kbs goinf to my Yamaha RXV100D amp. I have had this configuration for about a year now and it sounds so much better that before when I had another sound card that wasn't bitp-perfect.
I hope this is all of some help and whatever you do, don't give up because once you achieve bit-perfect playback you won't want to go back.
Russell
Similar threads
Trending threads
Latest News
Linn announces Majik DSM digital streamer upgrade
  • By Andy Bassett
  • Published
Sony announces WH-1000XM4 noise cancelling headphones
  • By Andy Bassett
  • Published
McIntosh launches C22 Mk V preamp and MC1502 power amplifier
  • By Andy Bassett
  • Published
Marantz unveils 12 Series Special Edition models
  • By Andy Bassett
  • Published
Samsung Galaxy Note 20 smart phone models launched
  • By Andy Bassett
  • Published
