Fozzie Bear
I know this subject has been asked numerous times before and I have trawled the internet looking for a similar scenario to my setup but have decided to ask the community here for ideas.
I have recently purchased a FireTV Cube which is connected to my Onkyo TX-SR507 and now controls the attached AV peripherals via HDMI CEC. Sound from any attached devices is now routed to the surround sound system and the TV speakers turned right down. (Prior to this all devices were directly connected to the TV via individual HDMI or Scart leads and were selected by the TV remote).
I have a pair of Sennheiser RS130 wireless headphones which previously worked fine with any attached video/audio source but have now stopped working. The Sony TV has to option to either mute the sound when headphones are plugged in or direct audio to the TV speakers AND the Headphone socket simultaneously. This was great if my wife wanted the TV sound down but I wanted to wear the headphones.
Since changing the connection setup I cannot get audio out of the TV headphone socket from any of the AV devices e.g. Fire TV, BD Player or Humax recorder. The only time it works is if I watch live TV via the built in Sony Digital Terrestrial Tuner.
Firstly I there a setting in the Sony TV which will allow HDMI audio to be transferred to the Headphone socket? Obviously this is the preferred solution as the setup is already configured this way. I have explored most options but cannot see anything in the settings which might be appropriate.
Secondly, failing an easy tweak above, will either of the following options work:
For clarification I am not looking for HiFi audio only basic stereo on the headphones. Unless absolutely necessary I don’t want to get into purchasing expensive Headphone amps for the few times I need to use the headphones.
Attached is a basic schematic of the connections for clarification
- Take Audio Out from pins 1 and 3 of the scart socket on the TV using an appropriate adapter and feed the Sennheiser transmitter from this?
- Can I use the left and right Surround Pre-Outs from the back of the Onkyo? Are these always active or only when 7.1 is selected as a speaker configuration.
- Purchase an HDMI Audio extractor such as this and connect the Sennheiser transmitter to it?
Notes Connecting directly to the headphone out socket on the front of the Onkyo is not possible as this mutes the speakers and cannot be altered.
My only doubt with options 1-3 above is the Sennheiser seems to be designed to connect to a headphone socket (which I believe is low impedance????) and if the output would be sufficient to drive the transmitter.
