ru555
Established Member
Hello fellow geeks i need a little advice please...
I'm currently running 7.1 - LCR, 2 x side and 2 x rear. and I want to add another 2 side speakers, as its a long room.
My decoder only has 4 signal outputs for rear channels (rear LR and surround LR) whats the best way to get two more signals from the surround channel to send to my amp?
My anthem d2v does have balanced (XLR) outputs that im not using, could i use the tow surround LR outputs from there? Are there any issues of delay etc with using a mix of balanced XLR and unbalanced RCA outputs to the amps?
thanks in advance
thanks in advance
