I have a speaker that looks like this :
What is the best solution for this? My thought is this :
Is this the way to go, or is there a better way besides repaint the entire case?
Note : The speaker case color is black piano (real)
BestRegards
- Grind it with a rough sandpaper so all cracks goes away, this will probably make the hole twice as big
- Grind it with a vary fine sandpaper
- Buy Plastic Padding and mix it with somekind of black paint pigment
- Try to apply the pianted plastic padding to the speaker case as even as possible
- Grind it with the vary fine sandpaper (if needed)
- Polish it
BestRegards
