muddybloke
Established Member
Hi all,
Nightmare - my home cinema system has just decided to pack in. I've got a Sony 5.1 DAV-SC6 DVD Home Cinema system.
Basically it the main dvd/amp unit. When i play dvds, after about 5 minutes the display counter will lock and i cant stop, pause, or return to the menu??? The dvd will continue playing though - i have to restart the machine if i want to stop it. All the rest of it seem fine.
Can anyone suggest what the best thing to do is? - it only had a 1 year warantee and is 2 years old.
Do you think if i took it into a sony store they could send it off to be fixed? - or is there another separate sony unit that i could buy to replace the naff one that would connect up to my existing speakers.
I dont really wanna buy another all in one home cinema system again when all the speakers work and it seems such a simple thing that doesnt work!?!
advice would be cool
thanks in advance
Muddy
thanks in advance
Muddy
