How to Fix iPhone X Won’t Turn on?
Discussion in 'Mobile Phones Forum' started by DivenLux, Jul 11, 2018.
  1. DivenLux
    DivenLux
    Jul 11, 2018
    4
    Los Angeles
    Share a repair case of iPhone X won’t turn on logic board repair.
    Disassemble
    Disassemble the won’t turn on iPhone X. Take out the double layer motherboard. Here comes the first difficulty – separate the folded motherboard. which requires severely temperature controlling. Excessively high temperature would damage the components around, but too low temperature cannot separate them. With patience and time, we separate the logic board successfully.
    [​IMG]
    Diagnosis
    After the logic board was separated, connect the upper layer with DC Power Supply. The reading current is abnormal. So we locate the fault to the upper layer. To continue our diagnosis, we measure power supply voltage of the upper layer with Multimeter. And find out there is no voltage value on C2771 and C2770. Measure with Multimeter and we can confirm that the inductor L2770 is damaged.
    [​IMG]
    Maintenance & Test
    So we need to take down inductor L2770 and replace with a new inductor. Firstly, attach the upper layer to the PCB Holder. And stick High-Temperature Adhesive Tape on components around L2770 for protection. Then re-solder with a new inductor. After cooling down, measure the current value again via connect it with DC Power Supply. The measured current value on the ammeter is normal this time. Fault cleared.
    [​IMG]
    Reassemble
    Guess what? Here comes the most difficult part of the repair – to remove tins from the two layers separately. We transfer the direction for 5 times and finally finish the tin removing process. Then another difficult part – to reball the lower layer. We actually made it only at our second attempt. Eventually, we got re-solder the two boards and reassemble the phone, the iPhone X won’t turn on the issue was finally solved.
    [​IMG]
    Check the iPhone won't turn on fix detail Video:
    How To Fix iPhone X Won't Turn On With...
  2. iceberg2014
    iceberg2014
    Jul 13, 2019
    USA
    Thanks for information
