Question How to fix green shadow on projector?
Discussion in 'Projectors, Screens & Video Processors' started by Xeradon, Aug 3, 2018.
  1. Xeradon
    Xeradon
    Jul 2, 2018
    2
    4
    Serbia
    Can someone please tell why is there a greed shadow and how to fix it. The problem is on Epson EH-TW2900. Lamp has worked only 400h. If I need some new parts where can I find them? I was searching for websites that ships worldwide or just Europe, but no luck.
  2. DB9S
    DB9S
    Oct 24, 2017
    56
    11
    UK
    +11
    To me it looks like either the panels have come out of alignment or a prism is out of whack in the optical path.
    Does it have panel alignment you can play with to see if it helps?
    If not and it is still under warranty, use that. :)
    Has it suffered a knock or suchlike recently?
