Grimmi68
- Joined
- Feb 11, 2009
- Messages
- 8
- Reaction score
- 0
- Points
- 54
Hi. I have no signal from a downstairs aerial wall point and have been up to the eaves of the house to try to sort this out. There are several coax cables up there with F-type connectors on them. I have a Labgear LDA2061LR up there and i thought i had to input and the outputs sorted out, but i had bought a klein tools coax tool, to check which cable went to the downstairs point, but none of them picked up the klein tools receiver, so obviously i have got the cables mixed up, up there. I have connected each cable to the TV and attempted to tune the TV in. None of the 5 or 6 cables got any signal, so I'm now not even sure that any of these cables are coming from the aerial. How can i determine which one is the aerial cable? There isn't a lot of room in the eaves and my arthritis limits how much movement i have up there (plus there's "stuff" in storage up there) so it's not easy to see which ones are routed outside (and we have cables coming from an old sky installation, too, to confuse things. So, I'm hoping there's a way to plug something on to each f connector that will tell me when there's an aerial signal, so i can then know i have the correct input cable. Can anyone point me in the right direction to solve this please?
Regards, Mark
Regards, Mark
