How to find hours on Z2 Bulb
Discussion in 'Projectors, Screens & Video Processors' started by Such, Sep 22, 2004.
  1. Such
    Such
    Dec 27, 2003
    2,255
    63
    Greenhithe
    +121
    Does anyone know how to find out how many hours use my Z2 has on the bulb? Cannot find in manual!
  2. anpool
    anpool
    To go to Factory Mode press select then press menu at the same time on the PJ itself (not the remote) and hold for about 2-3 seconds. I wouldn't change any settings in there though unless you are brave. But you can check the lamp hours used. To exit just hit the power button twice.
  3. UZUBAIRU
    UZUBAIRU
    Jul 6, 2001
    566
    28
    Manchester
    +27
    I hold down the 'On/Off' button on the remote for 30 seconds and it shows up in the top left hand corner of the screen.
    Umu
  4. Such
    Such
    Dec 27, 2003
    2,255
    63
    Greenhithe
    +121
    Thanks, I'll try these.
