How to extend length of Sky+ cables
Discussion in 'Sky Digital TV Forum' started by mrgrill, Mar 16, 2006.
  1. mrgrill
    mrgrill
    Hi there,
    I have a really annoying problem. I'm in the process of decorating and myself and t'uther half have decided to move the TV/Sky etc. The only problem is, the Sky+ box is currently next to the window, which is at one end of the house. The 2 Sky+ Dish Cables go through a small hole in the wall and outside to the dish.
    However, we are wanting to move the TV to a central wall in the rooom [getting a Plasma] and then have the Sky+ box here. My problem then is that I have to get the 2 Sky+ dish cables from where they come into the House now, to the centre wall of the room, but they are way too short.
    Is there any sort of cable extension for the dish input cables? Or would I have to get a sky engineer out to fit much longer cables, which I'd ideally not like to do?
    I've attached a Pic to try to explain my situation better.
    [​IMG]
    Thanks in advance.
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    You'll need some coax cable, either SATDS or CT100, F connectors and an F barrel (female-to-female connector to join the cables). You can get the cable information here: http://www.satcure.co.uk/accs/page8.htm
  3. Hairloss30
    Hairloss30
    Jan 4, 2006
    71
    +4
    mrgrill - I have the problem but in reverse. When Sly fitted the cable they gave me more cable than I needed incase I needed to move it. I have enough to run it into another room!
    neilmcl - how can I reduce the length of cable - is it a simple case of cutting it and reattaching the connector to put into the box?:confused:
  4. MeantToBeWorkin
    MeantToBeWorkin
    Just swap cables.
  5. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    Yes, just make sure you refit the F connector properly. This'll help http://www.satcure.co.uk/tech/fconn.htm
    I having nothing to do with this company btw I just think it's a really good source of information.
  6. MeantToBeWorkin
    MeantToBeWorkin
    Or just swap cables :)
  7. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    Swap cable with what :confused:
  8. DisguisedCoot
    DisguisedCoot
    Sep 26, 2005
    797
    46
    swindon
    +127
  9. MeantToBeWorkin
    MeantToBeWorkin
    Each other :)
    Measure them first, of course, but it would save buying cables, connectors, maybe tools.
    You never know, it might just work out ok :D
  10. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    Sorry, with you now, didn't realise you were referring to the posters.
  11. mrgrill
    mrgrill
    Thanks neilmcl. Cheers. But may I ask if you or anyone else knows if this will affect my viewing in anyway? I guess it won't but just wondering?
    thanks again guys
  12. Hairloss30
    Hairloss30
    Jan 4, 2006
    71
    +4
    Sorry "MeantToBeWorkin" but swap the cable's with what. As far as I am aware the cable comes from the sky dish on the chimey, through the wall and into the back of the sky box - swap the cable???? It's about 2 metre's too long which isn't enough to start climbing up on the roof or have I missed the point?:confused:
  13. MeantToBeWorkin
    MeantToBeWorkin
    In most cases, there's a cable that goes from the dish to a plastic box on your skirting or wall. Then there's a seperate cable that connects to this box, and runs to your Sky digibox. You'd need to check, but I'd be surprised if your cable ran straight from the dish to the digibox, for exactly the reasons you've stated.
    Assuming this to be correct, you can just unscrew the cable from your wall socket, and unscrew it from the digibox and replace it with a shorter one.
    My half-joke/half-serious suggestion to swap them was referring to the post by mrgrill too. mrgrill says his cable is too short. Yours is too long. If he unscrews his cable too, maybe you could just exchange cables via good old Royal Mail! It may save you both time cutting and re-attaching connectors.
  14. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    Actually that's quite rare. Most standard new installations involve a single cable run from dish to the box.
  15. mrgrill
    mrgrill
    I'll check the front of the house tonight, but eitherway it seems my options have been given to me. Thanks neilmcl and MeantToBeWorkin for the advice.
    Cheers.
  16. MeantToBeWorkin
    MeantToBeWorkin
    I stand corrected! Must have just been lucky in the last couple of places I've lived.
    Sorry for the misleading posts chaps.
