How to execute windows program when door opens
Discussion in 'Smart Home, Climate Control & Security Forum' started by rapsag, Nov 22, 2004.
  1. rapsag
    rapsag
    Hi, I need to activate a flash presentation on a computer with windows XP, when a door opens, so when some one enters a room the presentation starts playing, what do I need and how can I do this?
    Thanks in advance for your help.
  2. MuffKing
    MuffKing
    You need one of those pointer style remotes that plugs into the PC's USB port so that you can wire the switch on the handset to a door switch like they use on house alarms.
    Alternatively you could stip an old keyboard and bodge up the "F5" key to the door switch :D
