How to Enable the Dvi output on a 9500
Discussion in 'Desktop & Laptop Computers Forum' started by fatrich, Feb 25, 2003.
  1. fatrich
    fatrich
    Jun 21, 2001
    2,490
    halifax
    +31
    Can anyone advise how to enable the dvi output on a radeon 9500?, i have the MIke Parker mod which disables the VGA output, i have been told that if u use the dvi output with the dvi to vga toggle that comes with the card you can use the monitor.
    I have tried using the vga to dva toggle Win xp starts to load and gets as far as the win xp logo and then the monitor turns off.I have tried a couple of monitors and its the same every time,could it be that the resolution which i normally run at 1280x720 is too hot for my monitor, it normally works and i have to manually reduce the reslotuion.
    any advise is welcome
    thanks
    richard
  2. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    Richard, I've had a thought, have you got your PJ set as primary display, if so when it's loading the drivers and the XP logo's showing and PJ is primary it will switch to your PJ as the prefered dsiplay.
    Have you setup multiple displays in the ATI control whatsit, if so call the secondary display "PC Monitor" set the resolution to a more appropriate rez and apply a hotkey. You should then be able to "toggle" between PC monitor and PJ via the hotkeys.
    If this is "botox" forget it, if not and you dont follow I'll PM you my tel no, give me a call to talk thro'
    Steve
  3. fatrich
    fatrich
    Jun 21, 2001
    2,490
    halifax
    +31
    Steve
    i will try it tonight
    btw ive spoken to the wife she's dug out that cable so i will try and post it this evening in a jiffy
    regards
    richard
  4. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    No problem, if you want to call, anytime up to 10:00 is ok, or after 07:00 AM
    Steve
  5. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Suddenly everyone needs hotkeys;)
  6. fatrich
    fatrich
    Jun 21, 2001
    2,490
    halifax
    +31
    John
    is there any chance you can give me the edited version on how to do it,please
    cheers
    richard
  7. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    OK lets assume PJ connected to vga 1 and monitor connected via adapter to dvi.
    Make sure the ATI control panel is installed
    Right click on the desktop and choose:-
    properties/settings/
    make sure the resolution is set for the monitor you want to enable as primary, (doesn't matter if its not the one your on)
    click
    advanced/displays
    in the four up display you will only see colour on the connected monitors. VGA will be one of the top two. assuming both connected then you can make one of them primary by clicking the blue box with two white circles in it. you can turn a monitor off by clicking the red power button. Once they are arranged as you'd like for the 1st setting then type a name where it says scheme and then choose a hotkey eg "F1" and then save. You dont need to apply it at this point. If you want different resolutions on each monitor (probably) go back to the settings and change the resolution their, (it might make your picture out of proportion but dont worry at this stage) Go back to the display tab, enable the other monitor, set it to primary, disable the 1st monitor and save it as "setting" "F2".
    Esc to desktop
    Press "F1" or "F2" to select the correct single monitor and resolution.
    You can also use this and have extra settings for different resolutions/ referesh rates or dual head output etc.:)
  8. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    That's a perfect description Richard :lesson: unlike mine ;)
    John... you need to get out more :clown:
    Steve
  9. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    :blush:
  10. fatrich
    fatrich
    Jun 21, 2001
    2,490
    halifax
    +31
    Thank you John shall be playing tonight and Steve i have spoked to Gordon my new cable should be with me middle of next week
    cheers
    richard
  11. fatrich
    fatrich
    Jun 21, 2001
    2,490
    halifax
    +31
    Steve and John, i carried out the instructions last night and it works perfectly.
    thanks again
    richard
