How to create ....
Discussion in 'Desktop & Laptop Computers Forum' started by dUnKle, Sep 17, 2007.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,922
    +2,911
    a bootable CD-ROM which will allow me to format my C: drive for installation of WinXP
    I have a WinXP disc but for some reason it only installs, it does not format the drive
  2. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    What happens when you try to format using the XP disc?
    Plenty of bootdisk images here though http://www.bootdisk.com/
  3. dUnKle
    dUnKle
    Jan 1, 2001
    15,922
    +2,911
    Seems the one I need you have to pay for :(
  4. Uridium
    Uridium
    Jan 29, 2005
    14,434
    +1,855
    Plenty of freeware boot and utility CD's on torrent sites.
    I'd be more concerned why the XP format utility won't work. If it's unable to format you disk then it's likely to be a hardware fault with the hard disk.
  5. dUnKle
    dUnKle
    Jan 1, 2001
    15,922
    +2,911
    The disc does not have the option to format - its a disc that came with PC and it installs XP but not with a format - just installs over what you have already
    It came with a seperate disc that would format dic, allow you to partion etc but in house move no idea where it went
  6. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    What type of cd do you have ? Is it a OEM install ?
  7. dUnKle
    dUnKle
    Jan 1, 2001
    15,922
    +2,911
    belive so - not 100% sure
  8. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    Can you boot from the CD? If not, then the CD doesn't have a boot image. You'll need to make a bootable CD, which is very easy.
    Copy the contents of the CD to C:\XPCD then follow the instructions outlined here.
