simplyme
Established Member
So once you have copied all your music to the PS3s HDD using PS3 Media Server (which I have done by pressing triangle on the folder and selecting copy...), how can I copy updated tracks over to the PS3 without having to re-copy the entire folder?
Is the PS3 smart, in that if I add new tracks to my folder 'music' and then press copy on this it will only copy the new material - or will it try to copy the entire folder again?
