How to copy films/videos from iphone back to pc/computer?
DrkAngel21
I copied some videos from pc to iphone 3gs (unhacked) using itunes a while back, how do I copy them back to my computer now? Any help would be appreciated thanks
peterjcat
Established Member
The capability is not built into the iPhone so you'll need to find a program for your PC to copy everything back over. Google should turn something up.
mrash
Established Member
if you select "sync all" on the videos tab in itunes, then you should see them in itunes. If you can see them in itunes, then you should be able to see them in the folders on your pc too.
pixlrik
It's so easy to do if you didn't use iTunes. It's drag and drop simple actually. But because you did you will need special software to do it. I don't know what though as I've never had to do it.
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
