how to cope with auto-resizing
Discussion in 'Projectors, Screens & Video Processors' started by davee, Sep 9, 2005.
  1. davee
    davee
    Jun 15, 2004
    706
    twickenham
    +58
    How do you guys with fixed screens cope with auto resizing when you have a 16:9 screen. In particular dvds that have a variety of trailors featuring films that can be all sorts of ratios means that the pj is constantly resizing the image to suit the info encoded on the dvd. :rolleyes: Once the main feature gets going obviously all then settles down. At present I'm projecting onto the wall before deciding on the screen and size but curious to know how others deal with this...
  2. Kramer
    Kramer
    I never look at trailers/adverts etc., just have the main feature start. Easily done with a HCPC.
    Digital PJs are at their best after running for a while, 10 or 15 mins usually. Just enough time to get the popcorn & drinks ready :) .
    :smoke:
  3. KoThreads
    KoThreads
    Jan 18, 2005
    2,966
    +158
    i leave it on 16:9 and just put up with the rest. Autosize doesn't seem to work very well on mine, it gets confused and sometimes it's the film that looses out.
  4. davee
    davee
    Jun 15, 2004
    706
    twickenham
    +58
    There must be a more practical solution, not everything is in16:9 anyway :mad:
  5. 0B1-1
    0B1-1
    it's no different to watching on a 16x9 TV. You just have a 16x9 projection screen and the PJ will transmit either a 16x9 image with no black bars, or a 1.85:1 or 2.35:1 image etc with black bars at the top or bottom to compensate.
