how to convert MP3 for cd changer..
stolt
Hi I 've just bought a car which has a Pioneer 6 disc cd changer in it, but it's about 10 yrs old so won't play MP3, is there anyway I can convert the mp3 to play in this changer. Also if I can't do it that way, can you just change the cd changer rather than the head unit aswell, I know you prob can't change between brand ie, have a pioneer head unit and a sony changer but how bout if I bought the same brand just a newer changer from pioneer?
thanks for looking
KraGorn
You can use something like Nero to burn MP3s to an audio CD, is that what you're after?
stolt
yeah thats the kind of thing, I didnt really want to buy a MP3 changer unless I could really help it. I sit just a simple process of adding the files to a window and burning them.
probedb
Yeah in Nero just create an audioCD and drag your MP3s to it, it'll do it on the fly when burning :)
