how to connect
Discussion in 'AV Receivers & Amplifiers' started by tcgills, Dec 29, 2002.
  1. tcgills
    tcgills
    Dec 26, 2002
    92
    just purchased an av how do i connect my 5.1 television to av ,audio out has centre front rears not just the 2 audio outs sockets as normal do i just connect to fronts? bit confused i hope this makes sense hoping for some replys thanks:confused:
  2. LDR
    LDR
    Apr 1, 2002
    2,295
    Wales
    +98
    Give some info on what equipment you have and we will be able to help you out..
  3. tcgills
    tcgills
    Dec 26, 2002
    92
    I have marantz4200, panasonic 5.1 dolby tele
  4. LDR
    LDR
    Apr 1, 2002
    2,295
    Wales
    +98
    DVD player, VCR, SKY/Cable ?
  5. tcgills
    tcgills
    Dec 26, 2002
    92
    sony dvds336,sky pace,cheap old LG vid
  6. LDR
    LDR
    Apr 1, 2002
    2,295
    Wales
    +98
    You'll need 3 pairs of phono leads to connect each piece of equipment to the Sr4200, connect your DVD players digital output to the relevant input on the amp, be it co-ax or optical and then connect your external speakers. Make sure that when you go into the on screen menu you assign the DVD player with the correct digital input.
  7. tcgills
    tcgills
    Dec 26, 2002
    92
    But how do you connect tv when it has got front centre rear audio conections coming out of it
  8. xio
    xio
    Connect your sound sources from sky, vid, dvd to the amp as previously stated and just turn the sound off on the TV.
  9. GYoung
    GYoung
    Aug 23, 2002
    89
    +10
    I think the problem you have is which of the six phono outputs from the TV to connect to the amp. I may not be the best person to answer, but I suspect you'll need to connect all six to the amps corresponding inputs. The TV manual should tell you, or if you've lost it I think you can download one from Panasonic's site.
