How to connect.......
Discussion in 'Digital TV & Video Players & Recorders' started by Parmenion, Feb 18, 2002.
Tags:
  1. Parmenion
    Parmenion
    Feb 6, 2002
    1,281
    Out there
    +65
    My NTL cable box outputs its signal to my Denon amplifier via a scart to S video. The signal then goes from the amp via S video to my projector.
    The problem is..........How do I connect my Akai VHS video into the system?
    When I connect the Cable box to the video, via Scart, and then from the video to the amp, I get a picture in black and white on the cable channels and on the video.
    Anyone have any ideas?
    Regards
    Parmenion
  2. Doubledoom
    Doubledoom
    The black and white picture is because you are mixing s-video and composite video up.
    The generic connections response is below. Adapt it accordingly.
    Various ways to connect depending on what you think is acceptable.
    option 1 - RGB for both DVD and digibox but need to record via the RF.
    Audio carried from TV to Amp and DVD to amp (TV passes audio from vcr and
    digibox)
    DVD > Digibox VCR scart ( use scart lead, set DVD to output RGB)
    Digibox > TV (use scart lead into RGB scart socket)
    Video > TV (scart lead into composite scart socket - Don't use an expensive cable, it would be wasted)
    Aerial > digibox > vcr > TV
    DVD > Amp (using digital co-ax or optical -identical quality, depends on your available connections)
    TV > Amp (using 2x phono connection)
    Option 2 - RGB for digibox and s-video for DVD. Allows recording via the scart. Audio the same as above
    DVD > TV (scart into s-video scart)
    Digibox > TV (scart into RGB scart)
    Digibox > VCR (composite scart - Don't use expensive cable for this one)
    Option 3 - TV doesn't pass audio or doesn't pass it with decent quality. Will require manual switching between sources. Use video connections as option 1 or 2.
    VCR > Amp (using 2x phono connection)
    Digibox > Amp (using 2x phono connection)
