how to connect?
Discussion in 'Plasma TVs Forum' started by mdanforth, Mar 5, 2005.
  1. mdanforth
    mdanforth
    Feb 21, 2005
    193
    Cambridge
    +4
    Looking for the best picture quality but how to connect?
    Got the PW7 from 123 Electricals yesterday with the scart board. The Panny is fantastic, a big thank you to everyone who has wrote good things about this display and who convinced me to get one.
    I've currently got a Sky+ Box, a MAC mini and a Panasonic E55 DVD recorder.
    Have been looking at the JS tech VGA box for the sky+, looking at getting DVI board for the recorder or maybe using the scart, in which case using the DVI for the mac? Or the scart for sky+, DVI for DVD and the VGA input for the mac.
    Any help in a better way would be of great help!!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    do you have an AV amp?
  3. mdanforth
    mdanforth
    Feb 21, 2005
    193
    Cambridge
    +4
    Just a old basic Sony one, no special connections on it.
    Will be looking at getting a new one in the future but a while off yet.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    DVi for mini mac
    Component for DVD and run Sky into E55 and then onto componet on screen (JS RGB>VGA or RGB>YUV will look better tho)
    PS yes this does mean the scart board is unused and potentialluse less
    but without spending any money you can do as i guess you have already figured
    Sky>E55>Scart board
    mac mini>VGA
  5. mdanforth
    mdanforth
    Feb 21, 2005
    193
    Cambridge
    +4
    Thats brilliant, i'll get ordering and give it a go. Thank you so much for your help.
  6. Roswell
    Roswell
    Is there much in it quality-wise between the JS box and an E55. The E55 would be a lot more useful! :thumbsup:
    BTW, is there much difference between an E55 and an E65 apart from playing flash card jpgs and DV input. Both can be done well on a PC anyway so is there anything else that would justify the extra cost?
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    lip sync can be more of an issue using the DVDR to convert as some have found....but i agree more useful...the E65 is dirt cheap at RS at the moment
  8. Roswell
    Roswell
    Thanks. The lip-sync could be fixed with an AV amp but would the picture be much different quality-wise?
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    JS will be cleaner, ask Cardiff irons who had an E65 and migrated to JS RGB>YUV and said Q did get a bit better but lip sync was gone....
  10. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    js was better (vga) when i moved up from e55 too...very noticeable improvement
  11. Roswell
    Roswell
    Ok, thanks for the info. Maybe JS box still the best way to go then if it's a noticeable improvement and not just marginal. I've messaged Cardiff Irons to see what he thinks anyway.
