How to connect
Discussion in 'Cables & Switches' started by Phibot, Aug 10, 2004.
  1. Phibot
    Phibot
    I have a YAMA AMP and a Panni Projector and have just received my Vid card to go into my HTPC
    The Vid card is an X800 Pro and has S-video, DVI-I and a VGA output
    I would like to connect the VGA to a 17" monitor so I can view general TV but when I want to watch movies can bring in my projector.
    The question is this:-
    I want to send my signal from the Vid card to my Amp which supports the following inputs:-
    S-Video
    Component
    Composite
    The Amp will then convert either of the above inputs to Component which I will then take directly to my projector
    So do I jsut use the S-video or should I use the DVI-I and convert this to componet prior to connecting to the Amp, is this possible and what will give me the best solution.
    many thanks
    Ps the reason I want to go through amp is I will also be connecting my TV/VCR to the AMP and may want to put this through the projector .
    Hope you can understand all this its hard to explain... never mind physically acheive it!!
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,738
    The Borders
    +3,080
    Phibot
    If you projector has a DVI Input I'd connect the Graphics card directly to this Input.
    If your projector doesn't have DVI but does have VGA then I'd suggest you add a 1:2 VGA Distribution amp and send VGA to both your 17" monitor and your Projector.
    I'd run a second analogue YUV cable to the projector from your AV Receiver to cater for all of your analogue signals.
    Taking the output from your graphics card as Composite, S-Video or RGB Component (via DVI) and then converting to YUV in your AV Receiver will look terrible.
    Best regards
    Joe
