Question How to connect Xbox One Controller...
Discussion in 'PC Gaming & Rigs' started by Tidy_Sammy, Jun 9, 2015.
  1. Tidy_Sammy
    Tidy_Sammy
    Jul 31, 2007
    1,658
    Edinburgh, Scotland
    +225
    Hello dudes! My old Xbox 360 controller is giving up the ghost slowly, plus the d-pad is horrible (I play a fair bit of Mortal Kombat X, having to use analog sucks). My wireless Xbox One controller arrived today, I know I can't use it wirelessly yet until MS release the adapter, but from what I understood it could be run wired in the meantime? I tried using my Nexus 5 cable (Micro USB-USB), but I couldn't get the light to stay solid, am I doing something wrong? :(
  2. GMC79
    GMC79
    Apr 1, 2006
    10,668
    Glasgow
    +3,187
  3. Tidy_Sammy
    Tidy_Sammy
    Jul 31, 2007
    1,658
    Edinburgh, Scotland
    +225
  4. Tidy_Sammy
    Tidy_Sammy
    Jul 31, 2007
    1,658
    Edinburgh, Scotland
    +225
    Installed the 64-bit drivers onto my W8.1 system (all updates installed), when I press the home button it just flashes white, I think my cable is a micro USB charging cable, which is why it's not sending data across, argh!
  5. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
    It should just be plug and play, Ive used the Xbox One pads with my machines and I just plugged em in via USB and let Windows do its thing.
    Worst case, if youve installed the drivers manually from Ms, just set the driver manually in Device Manager.
  6. ODB_69
    ODB_69
    Feb 8, 2008
    12,891
    3
    2
    Englishman in Scotland
    +2,641
  7. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
    Thats not too bad... Im kinda looking forward to Windows 10 specially as its free!
  8. ODB_69
    ODB_69
    Feb 8, 2008
    12,891
    3
    2
    +2,641
    I'm in 2 minds whether to upgrade or leave it 8.1
  9. Nivek TT
    Nivek TT
    Feb 27, 2006
    6,694
    Bristol
    +2,197
    Steam Gamepad will rule them all :D
    Once some clever coder gets his hands on this it will be working on XP, 7, 8, Linux, Android, etc. within days.
  10. ODB_69
    ODB_69
    Feb 8, 2008
    12,891
    3
    2
    +2,641
    Tbh I assume Valve will release the coding for it anyway as they know someone will do it. Bit like MS did with the kinect
    Then will be the image of the pad with some modified lord of the rings text across forums globally
  11. Apsilon
    Apsilon
    Senior Moderator
    Sep 15, 2006
    14,722
    Manchester
    +8,013
    I remember when I first attempted to setup my wireless 360 pad, it simply wouldn't have it. It registered the dongle in device manager but, it wouldn't 'connect or talk' to the pad so to speak.
    I uninstalled and reinstalled the drivers (try W7 drivers) and then when I pressed both the connection buttons on the dongle and pad, it worked. Once it connects successfully, it will always connect. It's just that first time, that can sometimes be problematic.
    I think the pad can be run via the USB cable but again, you'll still need the dongle drivers as these are what enable the pad to work with the PC :smashin:
  12. Nivek TT
    Nivek TT
    Feb 27, 2006
    6,694
    Bristol
    +2,197
    @ODB_69 sorry I meant the Xbox One dongle will work with everything once some clever coder gets his hands on it.
    Agree that Valve will get the Steam gamepad working with everything.
    I wish we could get some sort of standardised wireless protocol (better than bluetooth). I'm getting a lot of USB dongles poking out of my PC.
