How to connect Xbox 360 online
Discussion in 'Xbox Forums' started by Robbie09, Jun 17, 2008.
  1. Robbie09
    Robbie09
    Feb 14, 2008
    781
    +19
    just bought an Xbox 360 for my lad and he wants to get onto this xbox live
    we have a modem downstairs but the cable is to short to go to his bedroom
    is it possible to buy a wireless modem for downstairs ?? and if so will the xbox be able to work off this
    also if i do need a wireless modem which 1 do i go for ??
    any help really appreciated :smashin:
    apologize if this is in wrong section
  2. ukbootlegs
    ukbootlegs
    Feb 7, 2006
    4,053
    Northants
    +362
    get a netgear dg834n
    they are brilliant
    and then you coluld go for the wireless xbox card and connect that way.
  3. shaun n
    shaun n
    Jan 29, 2007
    183
    evesham,worcs
    +4
    we use a dlink wireless down stairs,which runs a lap top plus 3 xbox 360's all at the same time with no faults at all.dont bother getting the 360 wireless adaptor,we usethe belkin wireless g gameing adaptor on all three 360's and they work fine and are alot cheaper.a.t.b shaun
  4. Robbie09
    Robbie09
    Feb 14, 2008
    781
    +19
    ok nice 1 m8 where abouts can i pick these up from and what sort of price is a good one
  5. Pooon
    Pooon
    Dec 26, 2002
    7,399
    Canterbury, Kent
    +993
  6. Robbie09
    Robbie09
    Feb 14, 2008
    781
    +19
    Thanks for the link m8
    but what do i actually need to buy off there m8
    Ps3 for me im happy with that but might of a sneaky go on the Xbox why hes out ;):D
  7. Robbie09
    Robbie09
    Feb 14, 2008
    781
    +19
    got the wireless router all set up what do i need now to get the xbox online its to much hassle to get the cables from the xbox to the router
    what am i missing ??
    TIA :smashin:
  8. King Tones
    King Tones
    Oct 18, 2007
    35,961
    2
    In The House Of Flies
    +17,599
    If you connect an Ethernet cable from the router into the Xbox and then you should be able to get online. If an Ethernet cable isnt an option then you will have to get the Wirelss Adapter for the 360.
    Deftones82
  9. Robbie09
    Robbie09
    Feb 14, 2008
    781
    +19
    it would be to much of a ball ache to connect via cables so whats sort of gaming adapter can i use is there more than 1 if so what do you recommend TIA :smashin:
  10. Pooon
    Pooon
    Dec 26, 2002
    7,399
    Canterbury, Kent
    +993
    If you have a broadband connection with Bt, Talk Talk, etc then look at the routers on this page Clicky!
    if however your with Virgin look hereClicky!
    and to connect your 360 wirelessly to the router, the easiest way(but not cheapest) is to get one of these Clicky!
    hope that helps
  11. Robbie09
    Robbie09
    Feb 14, 2008
    781
    +19
    nice 1 m8 thanks for the links :smashin:
