How to connect Wharfedale Diamond 12.2 to Marantz NR1510
kachijs
Hi! I recently bought used Marantz NR1510 receiver and after some reserch bought used Wharfedale diamond 12.2 speakers.
im still totally new to all this. I looked for specs and speaker manual says:
nominal impedance is 8 ohms (comptible) and miniaml is 4 ohms.
Now Marantz manual says:
So what would be correct impedance for this setup? 8ohms?
If it matters: i bought used wire: in-akustik LS-502 to use for this setup.
stranger
Always set your receiver impedance to 8ohms no matter what speakers you use, anything else will be detrimental to the sound quality.
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
