How to connect TV\Freeview\DVD Recorder?
Discussion in 'Cables & Switches' started by boppa, Feb 25, 2005.
  1. boppa
    boppa
    I've been searching the forums trying to work out how it would be best to connect these three pieces of equipment, but I haven't been able to find anything that would work (mainly because my TV has only one scart socket :(). So, I was wondering if you could help.
    Details:
    TV: Philips 23PF8946
    1 x RGB scart
    1 x S-Video
    1 x Composite
    1 x VGA
    DVD Recorder: Sony RDR-GX700
    1 x RGB scart ('TV')
    1 x non-RGB scart ('Decoder')
    1 x Component out
    1 x S-video
    1 x Composite
    Freeview box: Sony VTX-D800U
    1 x non-RGB scart ('VCR')
    I would like to use RGB where possible for the best quality, but I realise that beacuse the TV only has one scart this may not be possible (unless I got some sort of scart switch box; if so, any recommendations?).
    The other complication is that I would like to use SMARTLINK between the freeview box and the DVD if possible. However, in the DVD manual it says that I can only use it through the TV scart, but with the ouptut selected to Video, and that I must use the VCR scart on the freeview box.
    I just can't figure out what would be best!
    Thanks in advance,
    boppa :smashin:
