how to connect Sony VTXD800U to amp/projector??
Discussion in 'Satellite TV, Sky TV & FreeSat' started by dealmaker, Sep 24, 2003.
  1. dealmaker
    dealmaker
    Feb 21, 2001
    740
    nearly in Scotland!
    I'd like to connect my Sony VTXD800U through my Denon 3801 and in turn to my projector via component.
    Anyone any ideas how I connect the freeview box to the amp - as the amp does not have scart sockets and the freeview box only outputs via scart
    the Denon amp can accept component or s-video signals - I dont know about RGB ??? (or is that the same as component?)
    many thanks
  2. Kramer
    Kramer
    No, component & scart RGB are not the same.
    You'll need a scart to component convertor - try a search in LCD/DLP PJs - lots of discussion about such recently.
    If you're PJ accepts scart RGB, you'd probably be better feeding that directly.
    :smoke:
  3. jonbar
    jonbar
