How to connect Sky to projector?
Discussion in 'Sky Digital TV Forum' started by matblack, Jun 3, 2005.
  1. matblack
    matblack
    Jul 30, 2003
    406
    +10
    Here is my situation
    I have a projector at one end of the room with cables run from the front of the room via the ceiling, this means I am limited to the following cables
    VGA
    S-video
    Component
    I am considering getting sky for the room (standard Sky not +) I ran a Sat grade cable when I built the room so I can run the signal down there.
    The Sky box will sit with the following sources
    Marantz SR5400
    PC
    Tosh DVD
    I understand that the only output from most Sky boxes is SCART and in my wisdom I did not run SCART to the projector, nor can I, ceiling is now plastered.
    How should I get the SCART Sky signal to the projector to give the best picture, I'd ideally like to use the Marantz's switching which will handle component SCART or composite (bleugh)?
    Thanks inn advance
    MB
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    You can get a scart -> VGA or scart -> component converter from JS Technologies: http://www.js-technology.com/ that would do the job.
    HTH
    John
  3. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    RGB out of the Sky box, through a JS Technology RGB to component converter and into the Marantz.
  4. Astaroth
    Astaroth
    Jun 22, 2004
    3,653
    2
    London
    +882
    Probably the best way to do it would be to get an RGB->Component convertor and then I assume you will be able to put the component through your AVR
  5. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,737
    71
    Land of the Living, Essex
    +35
    What they said :)
  6. matblack
    matblack
    Jul 30, 2003
    406
    +10
    £145!
    Flipping heck :suicide:
    My wife will hit the roof
    So I presume that all the Marantz will do is switch between the sources and not do any conversion
    I have the S-video in the roof (put in just in case) how much difference will converting to component make? £145 worth?
    MB
  7. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You could think about upgrading to Sky+ which has s-video output ?
  8. matblack
    matblack
    Jul 30, 2003
    406
    +10
    Won't a SCART > S-video converter do the job?
    [​IMG]
    MB
  9. Robert_Webb
    Robert_Webb
    May 31, 2005
    7
    The SCART converter you pictured might work, although I have one like that and the output from S-Video is awful, distorted and in black and white.
    The RGB to component would work fine, but many newer Sky boxes have an S-Video output, it is not just limited to Sky+ boxes. Mine is a Grundig and has one, so if you happen to get one with an S-Video output you could run it straight into the projector.
