How to connect screw spades to cat5
Discussion in 'Cables & Switches' started by Matt, Oct 22, 2005.
  1. Matt
    Matt
    Jul 13, 2000
    777
    Cambridge
    +20
    I'm making a set of Cat5 cables and need to connect some of them to spade terminals so i can connect them to my rear speakers. I''ve got the spades but i have no idea how i am supposed to connect them. The spades look like this
    [​IMG]
    The Cat5 cable is a bit to stiff to wrap arounnd so not sure what to do really.
  2. Peridot
    Peridot
    Aug 24, 2004
    2,995
    Newport, South Wales
    +293
    Soldering would be your best bet, but I suspect that if you had the wherewithal to do that, you would have gone and done it by now :).
    Other than that, I think you need to find some spade terminals with screw down connections, or 4mm plugs if your speakers are compatible.
  3. Tezdread
    Tezdread
    cat5 to speakers? if one end is connecting to speakers what is the other end connected to? just intrigued as I only know cat5 for networking PC's
  4. Peridot
    Peridot
    Aug 24, 2004
    2,995
    +293
    Tezdread - see here
  5. Tezdread
    Tezdread
    what have I done lol
    I'll try reading through that lot when it's not so late/early, like when I get in from work ;)
    n1 Peridot
