Quantcast
How to connect receiver so HDMI inputs are mapped correctly?
Tremolo Arm
I have a Panasonic plasma directly connected via 2 HDMI cables to sky hd and PS3 respectively on HDMI 1 and HDMI 2. These are also mapped on my Logitech (all in one remote). No receiver is being used.
I am soon to be upgrading to a 5.1 surround system complete with AV receiver and speakers.
I noticed that the receiver has 3 HDMI inputs but only one HDMI.
Will the remote and TV correctly map the right HDMI port to the right source?
Bibio
depending on what AV amp you get then the amp will do the switching for you.
Sky conected to HDMI,1 then out to HDMI output from the amp to TV HDMI input1
PS3 conected to HDMI,2 then out to HDMI output from the amp to TV HDMI input1
you then use the supplied remote with your amp (or program your logitech) to switch channel e.g. input 1 for sky or 2 for ps3 the amp will then send the appropriate signal to your tv via the hdmi output from the amp.
so you will need 3 hdmi cables. 1 from amp output to TV input. 1 from sky output to amp input. 1 from ps3 to output to amp input.
