how to connect plasma help!
Discussion in 'Plasma TVs Forum' started by ted26, Apr 10, 2003.
  1. ted26
    ted26
    Apr 10, 2003
    511
    yorkshire
    +6
    i am new here so firstly hi to all :)
    i have just ordered a panasonic plasma and need help with the connections needed to set up my system!
    i have connected my xbox via svhs through a audio/video reciever which i think should be ok!
    dvd player will also go via svhs through my audio/video reciever which seems ok!
    sattalite seems to be the hardest to connect! i have a rgb scart output which i have converted to svhs with a small junction convertor! picture doesnt seem to be too good at all!
    it would be gr8 if i could route all cables through my video/audio reciever and send just one svhs cable to my plasma but at the end of the day picture quality is my priority
    i would like any help on all 3 subjects plzz. thx
  2. nathan_silly
    nathan_silly
    Try and use VGA/RGB/Component if possible.
    Has your DVD player got SCART/Component?
    XBox can use RGB and possibly Component as well. Sky would be best with RGB.
  3. jmack
    jmack
    dvd and xbox through your amp/reciever will be fine i would go with a rgb to vga from www.rgbtosvideo.com for best results and cracking picture that will leave the component imputs spare for when you upgrade your dvd player
  4. ted26
    ted26
    Apr 10, 2003
    511
    yorkshire
    +6
    dvd has scart output and svhs!
    sat box has just scart output?
    so which input r u saying use on the plasma :confused:
  5. nathan_silly
    nathan_silly
    DVD to Plasma- with SCART RGB lead.
    Sat Box to DVD player's SCART input (if it has one)
  6. ted26
    ted26
    Apr 10, 2003
    511
    yorkshire
    +6
    so jmack u r saying use the convertor to go from rgb in my sat box to vga into the plasma!
    dvd will be ok on svhs :)
  7. ted26
    ted26
    Apr 10, 2003
    511
    yorkshire
    +6
    sony dvpns700v is the dvd player if that helps
    has 2 scarts but dont know if ones a loop?
  8. jmack
    jmack
    yes rgb to vga straight into vga on plasma you could also get a scart 3 in 1 out and plug what ever rgb scarts you have into that then one into the vga box,
    the s-video will be ok for dvd but not as good as rgb scart or component,
    i can get a verygood picture through s-video but not as good as component but very watchable.
  9. ted26
    ted26
    Apr 10, 2003
    511
    yorkshire
    +6
    right so thats the video routed to vga :)
    just a question about the sound!
    how do i connect sound from my sky digi box! via 2 stereo jacks to reciever amp?
  10. jmack
    jmack
    i think you answerd your own question? unless you have digital out on there.
    post some pictures when your done good luck
  11. ted26
    ted26
    Apr 10, 2003
    511
    yorkshire
    +6
    thx for all help chaps :)
    jus gonna order the vga convertor and lead :cool:
    plasma comes friday and i feel like a kid at xmas :eek:
  12. jmack
    jmack
    take a look at the get ya plasma out for the lads thread that should keep you going till next week
