How to connect Panasonic SVHS VCR?
Discussion in 'Digital TV & Video Players & Recorders' started by verabgd, Sep 22, 2005.
Tags:
  1. verabgd
    verabgd
    Few days ago I received new Panasonic NV SV 121 EG S-VHS ET. I bought it online in Germany because I couldn’t find this model in Belgrade (Serbia and Montenegro).
    My problem is that I cannot get either video or audio on TV (as well as on PC monitor via Hauppauge PVR-350). I tried all possible connections: scart (I have 2), composite video and audio as well as S-video.
    On the other hand it seems that SVHS VCR is OK. I can turn it on/off, play VHS tape (although I cannot see or hear anything), FF etc. When I tried to get Menu to adjust this and that I didn’t get anything.
    Any idea what I am doing wrong?
    Thank you very much in advance.
  2. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    I thought this may be due to different TV systems in Germany and Serbia which would affect the tuner in the VCR but you both appear to use Pal B/G so that shouldn't be a problem. At least the website I checked on
    lists Yugoslavia as Pal B/G - guess they haven't caught up yet.
    You would have to programme your local channels into the tuner by doing a search scan so there must be some way of accessing the menu to do this. Presume that the tuner is analogue. There is a report that most of Germany now uses digital TV or cable
    http://www.german-way.com/paltv.html
    I would have expected a VHS tape to play in your new machine. One that you had previously recorded. You are switching your TV to the AV channel to view the VCR output
    I presume after connecting the vcr by scart cable to TV. You should also be able to view the menu when you do this.
  3. verabgd
    verabgd
    Thank you very much for your answer. It was the hardware problem although the VCR was brand new. Actually small electrical board for video output wasn't seated well. I suppose that it could happen during the transport although the service man’s opinion was that in the factory they didn't seat this board well. Anyway everything is OK now.
