How to connect old console which uses L/R audio (RCA) and S-Video to plasma
Discussion in 'Plasma TVs Forum' started by inert, Aug 15, 2013.
  1. inert
    inert
    Feb 8, 2011
    20
    Was wondering how I might be able to do this on an Panasonic ST50B. Would this be possible with any kind of adapter?
  2. Englander
    Englander
    Jul 23, 2013
    10
    If it's anything like the GT50, there isn't enough room on the back for the clunky red/white/yellow plugs, so you should have an adapter like this: Panasonic Genuine AV / Component Adaptor K2KYYYY00206 For Flat Panels | eBay which came with the TV. If you don't have one, you can buy one from ebay/a shop of your choice. This will allow you to use the composite connection with the TV.
  3. inert
    inert
    Feb 8, 2011
    20
    Thanks for the reply.
    It did indeed come with that adapter and it did the trick! :thumbsup:
  4. Englander
    Englander
    Jul 23, 2013
    10
    You're welcome - glad you got it sorted!
